free edition does not support FXO cards
Discussion in '3CX Phone System - General' started by ZenMasta, Mar 10, 2010.
  1. ZenMasta
    ZenMasta New Member
    Mar 10, 2010
    174
    I searched the phone system manual 8 pdf for FXO and found no results. I searched for PSTN and it says VOIP gateway only.
    Just want to confirm this.
    Is there a side by side comparison of free vs SBE/Pro etc besides this
    http://www.3cx.com/phone-system/3CXPhoneSystem_brochure.pdf
    It doesn't mention pstn/fxo stuff.
  2. comresource
    comresource Member
    May 22, 2009
    303
  3. leejor
    11,116
    329
    There is no difference in the supported FXO or FXS devices between versions, only feature availability.
    What specific FXO card are you wanting to use?
  4. ZenMasta
    ZenMasta New Member
    Mar 10, 2010
    174
    Thanks but there is no mention of FXO card support/pstn in the list. I'm kinda new to this in the first place so maybe I'm just missing some other lingo.
    bottom line is I have an open vox a400p card that works with trixbox and I know I can configure 4 pstns with it in trixbox. Can I do the same with 3cx free?
    I'm guessing not with an FXO card but only with that voip gateway that was mentioned. On the other hand, the flash animation on the home page depicts what looks like a 4 port fx card of some type.
  5. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Sorry, but you need to ask the "open vox a400p card" support team.
    They must know what is supported by the card.
  6. ZenMasta
    ZenMasta New Member
    Mar 10, 2010
    174
    Stepan, do you have a list of supported hardware somewhere? Do you have documentation that demonstrates/shows fxo hardware suport/configuration? The flash animation on the home page says
    Connect PSTN lines using low cost voip gateways & cards... so which cards? where can I find out.
    sorry for the edits. sometimes I reply too fast and then find the answer or get another idea :)
  7. SY
    3CX Support
    Jan 26, 2007
    1,825
    The "Links" to 3cx.com/blog and wiki.3cx.com are available
    P.S. But you should ask the supplier of your card anyway :)
  8. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,971
    280
  9. igor.snezhko
    igor.snezhko Active Member
    Jan 7, 2008
    668
    7
    Openvox make great cards for Linux - they are Dugium clones. But Openvox has not Windows driver (like Digium - he he).
    So you can only use a card that has Windows driver. Currently this is a Beronet,
