Free edition maximum extensions
Discussion in '3CX Phone System - General' started by jayp806, Mar 21, 2016.
  1. jayp806
    Feb 18, 2016
    I can see on the website that the free 3CX PBX software can have 2 simultaneous calls, but is there a maximum limit to the number of extensions it can have? Thanks.
  2. CentrexJ
    CentrexJ Member
    May 5, 2009
    433
    67
    With 3CX there are no limits to the number of extensions, digital receptionists (auto attendant), ring groups or call queues.
    The limits are simultaneous calls as well as if you have Standard or Pro edition.
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,325
    253
    The maximum number of extensions is based on the number of digits you pick for your extension length when installing.
    http://www.3cx.com/docs/installing-3cx/#h.vf5aeyogfnos
    2,3,4 or 5.
    In each instance, 1 is reserved for Voicemail, 1 for PIN Protect, 1 for Fax and 1 for Conference.
    With 2 - you can use 10-99 (85)
    With 3 - you can use 100-999 (895)
    With 4 - you can use 1000-9999 (8995)
    With 5 - you can use 10000-99999 (89995)
    In some cases, you may want to reserve internal extensions from being used - ie: in USA, 411 and 911 may not get used because these are used for other services and may cause confusion.
  4. daktur
    daktur New Member
    Oct 15, 2015
    226
    7
    I think the point is, how many extensions one can have since only 4ppl can talk in internal calls ou 2 in external and if you connect and extension to an external number than 1 call will take the 2 SC blocking any other calls.
    What you can do is configure your system and when it~s ready to go, buy your license with the proper number of SC according to your needs.
    Good luck!
  5. craigreilly
    Feb 1, 2012
    3,325
    253
    the point was clear: "is there a maximum limit to the number of extensions it can have"
