free edition simultaneous calls**FREE VERSION
Discussion in '3CX Phone System - General' started by smokeman, Mar 30, 2011.
  1. smokeman
    Dec 10, 2010
    50
    I noticed on the 3cx site, that simultaneous calls for paid versions starts at 4.
    How many simultaneous calls can you make with free edition...and is this extension to extension, or only simultaneous outside calls...?
  2. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    Re: free edition simultaneous calls
    Simultaneous calls includes ALL calls, internal, external, etc. I think the free version is also 4 but is missing some key features.
  3. leejor
    11,105
    329
    The "free" versions limit is four conversations. Usually, when the key supplied with a Beta is applied, it acts like a Demo key, unlocking all of the features but limiting you to two concurrent conversations.
