Free license question
Discussion in '3CX Phone System - General' started by Oli Robison, Feb 21, 2018.
  1. Oli Robison
    Nov 16, 2017
    11
    I have signed up for the free license and am trying to get it to appear in our partner portal, is there any way to do this as its not a paid license?
  2. StefanW
    Jun 2, 2009
    1,222
    93
    sure, during install enter your reseller ID or once installed you can "link" it from the Management Console Dashboard.
  3. Oli Robison
    Nov 16, 2017
    11
    Thank you, also can you still use custom domain and what happens after 1 year can you still carry on using ? I will be using 4 CC
  4. StefanW
    Jun 2, 2009
    1,222
    93
    custom domains is a PRO feature. Customers how had already a binding to a custom FQDN can remain using it. FQDN,SMTP,SSL are subject to the licensing modle. Annual keys fall down to an 4SC and will be currently supplied by 3CX of "expiry"...
