FREE version functions
Discussion in '3CX Phone System - General' started by abitec, Aug 20, 2013.
  1. abitec
    Nov 6, 2012
    11
    Please info if Free versions 3CX support "Digital Receptionist" and "Send call to voice mail".
    In the description fro Free version this is as supported function, but when I configure VoIP Provider "Connect to Digital Receptionist", then 3CX PBX Call terminate - in the logs is :
    Leg L:9.1[Line:10000<<90903722781] is terminated: Cause: BYE from PBX
    20-8-2013 12:34:38.567 [CM503008]: Call(C:9): Call is terminated
    20-8-2013 12:34:38.561 Leg L:9.2[Ivr] is terminated: Cause: BYE from 127.0.0.1:40600
  2. bardissi
    bardissi Member
    Jan 31, 2012
    318
    The free edition does definitely support auto attendant / digital receptionist. You may have a configuration issue possible with your trunk setup.
    Also make sure the 3cx servers are all running.
  3. abitec
    Nov 6, 2012
    11
    and function "Send call to voice mail" support also Free edition ? This also work not in my configuration.
    What of "configuration issue possible with your trunk setup" you mean. Any specifically ?
    All 3CX services are running.
    Regards
    Jaro
  4. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,978
    183
    Please post the verbose logs instead and remove the middle 2 octets of public IP's as well as any phone numbes for privacy.
  5. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    Digital receptionist should work no problems in the free version, as well as forward to VM.....
