Free version
Discussion in 'CRM / Helpdesk / App Integration' started by llc2, Sep 22, 2012.
  1. llc2
    Oct 13, 2010
    is the VAD available for free or demo version?
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    The free edition of the VAD only works with a few components. The most important featrues are not enabled.
    If you have doubts about if your project can be done or not with the VAD, ask your questions and we'll answer you, so you don't purchase a license if you can't do what you need.
