free version?
Discussion in '3CX Phone System - General' started by perler, Aug 12, 2015.
  1. perler
    Aug 12, 2015
    the pages to the commercial and free version are seem to link to the same files (for windows: 3CXPhoneforWindows14.exe).
    where do I get the free version and does it work with other SIP providers but offers google contacts integration as well?
  2. Saqqara
    Saqqara Active Member
    Mar 12, 2014
    877
    135
    Correct, same file for commercial and free - license key activates which version you are running.
    No charge for license for 'Free Version'
  3. perler
    Aug 12, 2015
    ok, so does this mean, that the free version needs the 3cx server component as well or can I connect to other providers too?
  4. Saqqara
    Mar 12, 2014
    877
    135
    3CX is a pabx system which has to be installed on a Microsoft desktop / server operating systems
    If you explain more what you are trying to use the software for, we maybe able to help you
  5. perler
    Aug 12, 2015
    ok, I see. I was just looking for a decent SIP client with Google Contacts integration. Installing a full PBX for this purpose is a bit over the top.
  6. leejor
    10,374
    231
    Since version 11, the3CX SIP "client" (3CXPhone) has been designed to be compatible only, with the corresponding version of the 3CX PBX. It will no longer work with other VoIP providers.
