French Prompt
Discussion in '3CX Phone System - General' started by georgeot, Dec 17, 2007.
  1. georgeot
    Nov 5, 2007
    5
    I want to know if you have a date for a final release of french prompt ?
    Watsoft, your french distributor send me a archive, but only some files are translate...
    Thanks in advance !
  2. georgeot
    Nov 5, 2007
    5
    no new information ?
  3. Mori
    Mori New Member
    Mar 23, 2007
    223
    Guess not. :)
    Think they are quite busy working on fixes relating to production.
    It is on to-do list but have not seen any suggestions on when its ready.
