Frequently used contacts
Discussion in 'Ideas' started by narkumas, Feb 14, 2017.
Frequently used contacts 5 5 1votes
5/5, 1 vote
  1. narkumas
    narkumas New Member
    Nov 28, 2016
    227
    29
    I would suggest a list of frequently used contacts. The Top 10 most used contacts on top of the presence-list.
