Fresh Install on Server 2008 R2 having errors
Discussion in '3CX Phone System - General' started by soltech2, Jun 16, 2013.
  1. soltech2
    Apr 1, 2013
    5
    I have done a fresh install of V11 on Server 2008 R2. I did all Windows updates before installing 3CX. The install finishes without problem, but when you try and goto the management console you get a blank white screen on FF after login and the following error shows up in the Application event log:
    Framework Version: v4.0.30319
    Description: The process was terminated due to an unhandled exception.
    Exception Info: System.Runtime.InteropServices.SEHException
    Stack:
    at System.Threading.Thread.InternalCrossContextCallback(Context ctx, IntPtr ctxID, Int32 appDomainID, InternalCrossContextDelegate ftnToCall, Object[] args)
    at System.Runtime.Remoting.Channels.CrossContextChannel.SyncProcessMessage(IMessage reqMsg)
    at System.Runtime.Remoting.Channels.ChannelServices.SyncDispatchMessage(IMessage msg)
    at System.Runtime.Remoting.Channels.CrossAppDomainSink.DoDispatch(Byte[] reqStmBuff, SmuggledMethodCallMessage smuggledMcm, SmuggledMethodReturnMessage& smuggledMrm)
    at System.Runtime.Remoting.Channels.CrossAppDomainSink.DoTransitionDispatchCallback(Object[] args)
    at System.Threading.Thread.CompleteCrossContextCallback(InternalCrossContextDelegate ftnToCall, Object[] args)
    at System.Threading.Thread.InternalCrossContextCallback(System.Runtime.Remoting.Contexts.Context, IntPtr, Int32, System.Threading.InternalCrossContextDelegate, System.Object[])
    at System.Runtime.Remoting.Channels.CrossAppDomainSink.DoTransitionDispatch(Byte[], System.Runtime.Remoting.Messaging.SmuggledMethodCallMessage, System.Runtime.Remoting.Messaging.SmuggledMethodReturnMessage ByRef)
    at System.Runtime.Remoting.Channels.CrossAppDomainSink.SyncProcessMessage(System.Runtime.Remoting.Messaging.IMessage)
    at System.Runtime.Remoting.Proxies.RemotingProxy.CallProcessMessage(System.Runtime.Remoting.Messaging.IMessageSink, System.Runtime.Remoting.Messaging.IMessage, System.Runtime.Remoting.Contexts.ArrayWithSize, System.Threading.Thread, System.Runtime.Remoting.Contexts.Context, Boolean)
    at System.Runtime.Remoting.Proxies.RemotingProxy.InternalInvoke(System.Runtime.Remoting.Messaging.IMethodCallMessage, Boolean, Int32)
    at System.Runtime.Remoting.Proxies.RemotingProxy.Invoke(System.Runtime.Remoting.Messaging.IMessage)
    at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(System.Runtime.Remoting.Proxies.MessageData ByRef, Int32)
    at Aprelium.FCGIDotNet_4_0.Host.ProcessRequest(Aprelium.FCGIDotNet_4_0.Connection)
    at Aprelium.FCGIDotNet_4_0.Connection.ProcessOneRequest()
    at Aprelium.FCGIDotNet_4_0.Server.OnRequestAccept(System.Object)
    at System.Threading.QueueUserWorkItemCallback.WaitCallback_Context(System.Object)
    at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
    at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
    at System.Threading.QueueUserWorkItemCallback.System.Threading.IThreadPoolWorkItem.ExecuteWorkItem()
    at System.Threading.ThreadPoolWorkQueue.Dispatch()
    at System.Threading._ThreadPoolWaitCallback.PerformWaitCallback()
    I have uninstalled and reinstalled several times and that does not resolve the issue. I have also removed .Net Framework and reinstalled, still no help. So I'm rather stuck at this point.
    Christopher
  2. cobaltit
    cobaltit Active Member
    Mar 22, 2012
    833
    127
    @Christopher
    I had a similar issue with a fresh install. I ended up repairing .Net 4.0 from the Programs menu, and then restarting all the services (3CX and IIS). It was a while back so I can't remember the exact message but it seems similar.
  3. soltech2
    Apr 1, 2013
    5
    I have repaired the .Net services, uninstalled and reinstalled 3CX and still have the issue.
  4. kevin
    kevin Member
    Nov 23, 2006
    316
    @crspencer
    Please try to load up the "Windows Management Console" and advise the outcome.
  5. soltech2
    Apr 1, 2013
    5
    I can get to and enter the username and password, after I click login I just get a blank white screen, though the system seems to be functioning properly in the background.
  6. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    I'd remove the site and appPool from the IIS config after uninstalling.. this and other apps tend to leave entrails in IIS after uninstalling.. messes up the reinstall most of the time.
  7. soltech2
    Apr 1, 2013
    5
    I'm using Abyss, not IIS.
  8. kevin
    kevin Member
    Nov 23, 2006
    316
    @crspencer
    For a deeper look at this from 3CX, you will need to open a support ticket.
