Friendly-Scanner
Discussion in '3CX Phone System - General' started by Wanderer, Nov 14, 2010.
  1. Wanderer
    Nov 9, 2010
    19
    I am experiencing an on going problem at the moment, our system keeps getting attacked by various using "friendly-scanner", although they are not getting access they are maxing my adsl bandwidth to 100%. I no sooner get rid of one then another starts.
    REGISTER sip:10.25.50.6 SIP/2.0
    Via: SIP/2.0/UDP 67.222.24.40:5114;branch=z9hG4bK-3613954783;rport=5114
    Max-Forwards: 70
    Contact: <sip:123@1.1.1.1>
    To: "015" <sip:015@10.25.50.6>
    Call-ID: 3284308801
    CSeq: 1 REGISTER
    Accept: application/sdp
    User-Agent: friendly-scanner
    Content-Length: 0
    If anybody has any ideas I would be grateful.
    Tim
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    You need to ask your ISP to block this traffic because even if you block it on your router/firewall it will still consume bandwidth of ADSL connection.
  3. Wanderer
    Nov 9, 2010
    19
    Hi Stepan
    Sorry to say, been there done that, and been told there is nothing they can do.
    Tim
  4. SY
    3CX Support
    Jan 26, 2007
    1,825
    Hi Tim,
    In this case I can suggest to restrict traffic on your NAT/firewall to allow only trusted networks (locations of the remote extensions/VoIP providers) to communicate with PBX.
  5. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    Not knowing what router you have, you could set your firewall to DROP these packets (meaning no reply) to save some bandwidth and appear stealth. eventually that may stop.
  6. Wanderer
    Nov 9, 2010
    19
    Deployed firewalls and all okay now.
    Thanks all
