FritzBox with 3cx software
Discussion in '3CX Phone System - General' started by afpr, Oct 12, 2007.
  1. afpr
    Oct 9, 2007
    Can i use fritz box to forward my calls to the pstn lines? if it's possible, can you help me?
    Any help would be much appreciated.
  2. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    I am not familiar with this device but from what I read on their site it would appear that the device can log into and use SIP providers or route calls on PSTN line depending on dial plans but not route PSTN calls to SIP. If you were receiving a PSTN or SIP call, your phones would ring and you would answer on same handset regardless of origin of call. If you were making a call the device would select VoIP or PSTN outbound depending on dial plans. So you could use 3CX as a SIP provider for it but you could not route PSTN call to 3CX with this device.
  3. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,971
    280
    Mirzab is right, you can not use this box to forward calls to the PSTN. You can just receive calls. I have raised this issue with AVM - because its easy for them to upgrade the firmware to allow this. If enough customers ask them they might make the change! So fire off an email to them :)
  4. Arnaud
    Nov 23, 2007
    43
    I'm considering to buy this device (at Ebay.de you'll get one for about 20 Euros), but got a bit confused about your posting.
    Aren't you contradicting eachother ?
    Thanks,
    Arnaud
  5. silentfun
    silentfun Member
    Dec 11, 2006
    364
    means you coud use the fritz box as a extension(phone) device (i am not shure that you can not route calls from PSTN to 3CX still experimenting but you are not able to route PSTN to 3CX if you config fritz box as a extension device.
    same like above but possible he means you can also receive calls from PSTN if the the fritz box is connectet with the PSTN (but in this case 3CX PBX have nothing to to with receiving calls from PSTN it is complete handeled by the fritz box.
    hope this helps
    i am for my self still probing / experimenting with some fritz box to missuse them as gateways if i find out a way i will give it to public
    Andy
