Frustrated with GXW4108
Discussion in '3CX Phone System - General' started by Firetec, Oct 23, 2007.
  1. Firetec
    Oct 15, 2007
    Hey guys, please help,
    I have a GXW4108 connected I followed everything perfectly in the 3CX provided setup here: http: //www.3cx.com/voip-gateways/Grandstream-GXW-41044108/ NO LONGER AVAILABLE. NEW LINK: http://www.3cx.com/support/
    One thing with the instructions, it says "Set the “Off hook Auto Dial(VoIP)” field to “ch1-4:yyyyy;” where yyyyy is the SIP User ID for the first line defined in the “Channels” page." In my FXO lines page there is nothing about Off Hook Auto Dial VoIP! I am using the latest firmware 1.0.1.2, but am having nothing but problems.
    Inbound routing seems to work, kind of, it takes 6 rings until the SIP phones start to ring!
    As for outbound, it doesn't work at all, do you have any suggestions? what other info do you need?
    -Rod
  2. alicic
    alicic New Member
    Oct 3, 2007
    119
    Change "Call Progress Tones" in Gateway to Country secific values, that it might work. You can see call progress tones for every countr at this web page
    http://www.3amsystems.com
    regards,
  3. Firetec
    Oct 15, 2007
    FYI, I am trying to put this behind a Panasonic TDA100 system with analog terminal adapters for the FXO lines (thereby simulating the PSTN). If I connect it directly to a real POTS line, it works fine, if I call the number, after 1 or two rings the SIP phones start to ring, but if it is behind the Panasonic ATAs, it the SIP phones will only start to ring after 6 rings into the FXOs.
    Also how would I set it up so when SIP phone number 1 goes off hook it allways uses FXO port 1, and lets say SIP phone 7 goes off hook, it and only it uses FXO port #7.
    You see basically what I am doing here is an analog to SIP converter.
  4. namster
    Sep 15, 2007
    I did this and it works:
    Contact Grandstream Support for the latest firmware or visit http://www.grandstream.com.
    Set the following values in the FXO Lines web configuration page:
    Enable Current Disconnect to Yes (if the PSTN provider utilizes Current Disconnect).
    Current Disconnect Threshold: 300
    Min Delay Before Dial PSTN: 750
  5. Firetec
    Oct 15, 2007
    I did all that you suggested
    "Contact Grandstream Support for the latest firmware or visit http://www.grandstream.com.
    Min Delay Before Dial PSTN: 750 "
    That was not the problem, the issue is that being behind a phone switch such as a Nortel or a Panasonic, you have to deal with the different ring cadences, or ring tones. When I was testing the system I was always calling internally thereby passing the internal ring cadence to the[/color] analog terminal adapter (SIP phones didn't ring till 6 rings). When I called from the outside world, back into the ATA, it will ring after 5 seconds, because the ring cadence is close to the regular PSTN, 2 on 4 off.
    I am still having issues with dialing out. like I said before, when I put a real PSTN line into the gateway, it works great everytime, but when I put it behind the ATA, it doesn't work. I listen to the dial tone of the PSTN and the dial tone of the ATA and the are identical, I am using 1 stage calling. Any suggestions?
    -Rod
