FTP Backups are not shown
Discussion in '3CX Phone System - General' started by das, Jul 13, 2016.
  1. das
    das
    Dec 8, 2015
    14
    FTP backups are working fine in V15. But the backups are not shown under Backup and Restore / Location.
    When using local disk, the backups are correctly shown.
  2. nb
    nb Support Team
    Jun 7, 2007
    2,117
    145
    Yes this can happen if they exceed 200 Megs in size.. And there is a limitation in the library that if they are over 200megs they cannot be displayed.
    Use this rule
    If you want to store on FTP, make sure you store configuration only and keep recs in a separate location or take 1 monthly backup and you know that it is there.
    Otherwise store backups in another folder. It's a limitation of the library. We have to live with this for now.
  3. das
    das
    Dec 8, 2015
    14
    The max. size of backups on FTP location is 32MB.
    I removed all backups and rechecked with backup of configuration only (61KB), but this is still not shown.
