Yeah, why should we use a phone to make calls?Why NOT use Outlook to make a call? We already spend a bunch of time there... why have to switch to another program to dial the phone?
With the outlook 365 integration you can do exactly that? Sync your contacts with the phone and dial easily from there....
Making calls from outlook means:
-Switch from Inbox to contacts
-Find contact
-Right-click
-select between numbers
Check your inbox!
We’ve sent you an email. Click on the button in the email body to verify your email address – (if you can not find it, check your spam folder).
Upon verification you will be directed to the 3CX setup wizard.
