Future CRM Support?
Discussion in 'CRM / Helpdesk / App Integration' started by Tim H, Mar 15, 2018.
  1. Tim H
    Aug 11, 2017
    7
    Any chance you are considering creating a link to the Commit System? http://www.commitcrm.com/
    It is for IT Firms and quite good. Looking for something built in so we do not have to play with this API.
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,611
    126
  3. Tim H
    Aug 11, 2017
    7
