FXO Backup Gateway Query
Discussion in '3CX Phone System - General' started by the-waves, Oct 4, 2009.
  1. the-waves
    Sep 16, 2008
    5
    Hi all,
    We are running 3CX 7.1 and it is ruuning well. However when the internet goes down we lose our phones. Is it possible to configure a FXO gateway (such as Vegastream or Grandstream) to recieve all incoming calls via a PSTN line and then make outgoing calls on that same line(s) when the internet goes down?
  2. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    If your primary trunk is a SIP trunk, then if you add another gateway device you can determine in your outbound routes to failover to a second or third route if one fails. Currently, 3CX supports up to 3 trunks per outbound route.
  3. the-waves
    Sep 16, 2008
    5
    Gotcha - thanks for your input on this - it is really appreciated. I notice you work with voipstore.. if you had to choose a patton or a grandstream gateway what would be your favored unit?
  4. the-waves
    Sep 16, 2008
    5
    Also would it be possible to use something like a Sangoma A200 card in the 3CX box rather than a separate physical gateway box?
  5. tpinnovations
    tpinnovations Member
    Jul 30, 2009
    296
    You can use a card, Just make sure its on the supported list.
  6. 888Mike
    Apr 27, 2009
    11
    In terms of my preference, the internal Sangoma Netborder Express cards are very nice if you want an all in one solution with top notch echo cancellation and quality. If you want external, the Patton Gateways are nice since they auto configure and have great quality. The Grandstream gateways also boast well and are very price competitive. If you have any questions just call 888-864-7786, ext 207 and I will walk you through it.
