FXO Hardware link for 3cx
Discussion in '3CX Phone System - General' started by cfmiT, Aug 21, 2007.
  1. cfmiT
    Oct 14, 2006
    Hiya Everybody, Brand new NEWBIE - first post! :idea:
    I am looking to use 3cx directly from my PC through a HiDef Voice MODEM plugged into my PCI slot and acting as my FXO connection to my
    BT telephone line in the UK.
    1. I need good quality sound
    2. I need to detect and present BT Caller ID polarity reversal.
    Can anyone assist me I have used trixbox in the past with an anologue modem X100P I want to achieve the same hardware end result
    3. I need info on drivers for my project also
    cfmiT
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,991
    304
    Modems are not supported. You have to use a supported VOIP Gateway, see FAQs for more info.
  3. cfmiT
    Oct 14, 2006
    Thanks for your instant reply. Much appreciated!!
