FXO hardware
Discussion in '3CX Phone System - General' started by Pentangle, Jan 2, 2008.
  1. Pentangle
    Pentangle Member
    Dec 6, 2007
    261
    Hi all,
    Since Linksys bought Sipura and started mucking around a bit with their product offerings, they seem to have settled on the SPA-3102.
    This is pretty cheap (at about £35+VAT).
    My question is - what other FXO devices (if any) on the market are compatible with 3CX around that price point? I'm thinking purely at the SOHO marketplace for this (so I don't expect to find a Patton gateway for that price!!).
    Just curious, so don't spend loads of time on this if you haven't got it to spare!
    Cheers,
    Mike.
    (p.s. - the new bugfix version of v5 definitely feels more stable both on extension and VoIP provider line accessibility! well done guys!)
  2. Wardy
    Wardy New Member
    Sep 18, 2007
    110
    The only sub £100 one that I was able to find was the SPA-3102
