FXO PCI
Discussion in '3CX Phone System - General' started by caiotoledo, Feb 24, 2014.
  1. caiotoledo
    Jan 15, 2014
    19
    I would like to know if FXO PCI works well with the 3CX Phone System 12.
    Anybody ever tested that?
    11,277
    360
    Which FXO PCI card are you talking about?
  3. cobaltit
    cobaltit Well-Known Member
    Mar 22, 2012
    1,766
    277
    Sangoma cards will work in conjunction with the Netboarder Express software, although it is no longer supported from a 3CX standpoint.
