FXS/DECT - No Dect?
Discussion in '3CX Phone System - General' started by pact, Jul 7, 2016.
  1. pact
    pact New Member
    Dec 16, 2009
    219
    41
    I'm assuming this is just an incomplete section of V15.
    In FXS/DECT you can only add a Fax?
  2. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,380
    84
  3. 12494
    12494 Member
    Apr 16, 2010
    306
    31
    Guessing this didn't happen in SP2, based on what I am seeing.
    A.
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,445
    540
    No i didn't make it in SP2, but it is coming in the next update which is right around the corner
