fxs + fxo patton config
eddy18
hello world
I have a configuration for 2 FXO and one for
2 FXS. Operate separately .. Someone I know how to make a single
configuration file to run 2 FXS and 2 FXO SN4114 for a
3CX?
(file attached)
thanks
  • patton.zip
eddy18 said:
hello world
3CX?
(file attached)
thanks
hello,
your answer is it's possible to intégrate in patton sn4114 to configuration ? and if i was in 1site i use first configure and in the second the second config ?
if it's this it's not possible (for the moment, maybe you can send email to patton to add this fonctionnality).
explain ...
I make my Patton SN4114 (2fxs + 2fxo) for the 3CX .. I search for a configuration file ..
thanks
This device is not supported by 3CX - that is to say it will work if you configure it correctly but you will need to be familiar with how to configure a Patton.
If you stick to the supported models then you can use our configuration files. We only make config files for the most popular models.
Getting Started - Admin
nick_bag
Get 3CX - Absolutely Free!
3CX
