FXS/FXO port and phones
Discussion in '3CX Phone System - General' started by Eliminateur, Nov 20, 2007.
  1. Eliminateur
    Nov 20, 2007
    i have some Micronet SIP FXS+FXO gateways and i wanted
    to know if 3cx product can handle a hybrid architecture with internal IP
    phones on one side and POTS phones connected to the FXS ports of the gateway(i.e: if the software can handle comms between POTS-IP phones and from POTS-gateway-PSTN comms).
    Can it also handle a complete POTS solution in which no-ip phones are
    present and a FXS gateway acting as bridge(POTS-PBX replacement/migration
    scenario which several customers present when changing to voip / ATA adapters).
    thanks in advance
  2. jb
    jb
    Nov 22, 2007
    5
    Yes, should be no problem.
    Here's the 3CX config guide for some Micronet gateways.
    http://www.3cx.com/voip-gateways/Micronet-SP5050.html
    As far as 3CX is concerned the FXS phones are the same as any other IP phone extension - provided the Micronet is setup properly.
