fxs ht-488
Discussion in '3CX Phone System - General' started by jits04, Jul 27, 2007.
  1. jits04
    May 2, 2007
    76
    I have some problem to call from a phone connect to fxs of ht-488? 3cx is works without problems. I can place calls on FXO port without problem from other phones connected to the network. I have just problem for phone connected directly to ht-488. Have you connect it without problem? Can you post parameters?
    William
