G.711 Fax
Discussion in '3CX Phone System - General' started by magicrabbit, Jun 22, 2017.
Tags:
  1. magicrabbit
    Jun 22, 2017
  2. teichhei
    Oct 11, 2009
    29
    No, unfortunately I'm also still trying to sort that out. Also can't find anything else that works guaranteed out of the box like a g711 ATA adapter. Some people just won't let go of their bloody faxes.
  3. complex1
    complex1 Active Member
    Jan 25, 2010
    814
    49
    For me... to receive faxes using G.711 work well since v15.5 (3CX on Windows)
    I don’t receive much faxes, but I do receive them now and without issues.
  4. magicrabbit
    Jun 22, 2017
    Hmm...... I'm running v15.5 on Server 2016 and I don't receive a transmission. Did you have to do any tweaking, or did it just work out of the box for you?
  5. complex1
    Jan 25, 2010
    814
    49
    No, I didn’t do any tweaking. Just work out of the box.
    It start working after the upgrade to v15.5
