G.722.2 HD Voice
Discussion in '3CX Phone System - General' started by mwaver, Dec 13, 2017.
  1. mwaver
    Dec 7, 2017
    12
    Hello
    I tested with the Pro Version from 3CX and the codec 711 was the best quality.
    G722 should be better but was much bader.
    Could it be 3CX not use the G.722.2 codec?
    Thx
  2. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,379
    84
    3CX supports it, but where did you call? Was there transcoding involved?
    If 3CX had to convert G722 to some other codec because of e.g. both sides not both supporting G722, then it would depend on what codec it was transcoded to.
    If transcoding was not done, 3CX does not tap into the audio stream at all, so you would then want to investigate that at the endpoint level.
