G.722 v15 no HD calls
Discussion in '3CX Phone System - General' started by easydone, Dec 8, 2016.
  1. easydone
    Nov 22, 2016
    8
    I've installed v15 (fresh) but i can't get HD-voice (G.722) to work.
    I'm using a Fritzbox 7360 to connect to the pbx.
    It always connects with G.711.
    Even removed all codecs (except for G.722) from the trunks and extension, it still connects with G.711..
    What could be the problem?
  2. easydone
    Nov 22, 2016
    8
    Own fault, on the fritzbox HD-voice was disabled.
