G729 / PCMU - Callcentric
mbeijen
I have 3 DID's with CallCentric, the first line is a brand new line, the other 2 have been ported.
The first line works absolutly fine, the other two lines work fine as long as they go directly to an extention. When they go to an autoattendent, it's game over and the call gets dropped with the following message :
from 'bi-server:0/MediaServer':No RTP packets were received on 0000001C@:remoteAddr=204.11.xxx.xxx:54858,extAddr=76.212.xxx.xxx:9000,localAddr=0.0.0.0:9000
Callcentric did some research regarding this and told me the following:
On the first line the following codecs are used : G729,PCMU,PCMA
On the 2 ported lines it's just : G729 & PCMU
They were suggesting to disable some of the codecs in the 3CX system to see if that would help.
I looked around, and simply cant see a way to disable these at all. Is there a way? Does anybody have another solution or a suggestion?
Thanks a bunch!
Marco
Hi, Marco,
Both sets of codecs are good for PBX and for calls from/to this provider PCMU codec will be used independently of source or destination of call as well as independently of which line is used.
Definitely, it is not a codec issue.
This log entry just says that no RTP packets was received from remote party.
It is reported after call is dropped. PBX log contains other messages related to call. Please post it here to investigate source of problem.
Thanks,
Stepan
This is the piece from the 3CXPhoneSystem.trace.log , is this the one you were talking about?
13:47:20.062|DialogUsageManager.cxx(1190)|Trace5|Resip|>>:Got: SipReq: OPTIONS 0005*[email protected]:5060 tid=63093759 cseq=OPTIONS [email protected] / 102 from(wire)
13:47:20.984|.\Endpoint.cpp(75)|Trace5|Endpoint|Endpoint::findSource:No Remote-Party-ID header found
13:47:21.000|.\Endpoint.cpp(95)|Trace5|Endpoint|Endpoint::findSource:Lines Is here
13:47:21.000|.\Endpoint.cpp(110)|Trace5|Endpoint|Endpoint::findSource:Only one lines is here
13:47:21.000|.\Endpoint.cpp(116)|Trace5|Endpoint|Endpoint::findSource:Settings for caller is found: CfgExtLine:10002
13:47:21.000|DialogUsageManager.cxx(1190)|Trace5|Resip|>>:Got: SipReq: INVITE [email protected]:5060 tid=-6d832975e28c59947843a74fb0706a87 cseq=INVITE [email protected]:5060 / 1 from(wire)
13:47:21.000|.\CallMgr.cpp(285)|Trace5|CallControl|ADSFactory::createAppDialogSet:Creating ADS for INVITE
13:47:21.000|.\CallConf.cpp(405)|Trace5|CallControl|CallConf::CallConf:Call created: C:1B
13:47:21.000|.\CallConf.cpp(348)|Trace5|CallControl|CallConf::addCallLeg:Added leg# 1 to call C:1B
13:47:21.000|.\Call.cpp(1322)|Trace5|CallControl|CallLegImpl::CallLegImpl:Leg @L:1@C:1b is created
13:47:21.000|InviteSession.cxx(2046)|Trace5|Resip|>>:Transition UAS_Start -> UAS_Offer
13:47:21.000|.\ISHandler.cpp(21)|Trace5|CallControl|ISHandler::eek:nNewSession:Incoming: sis=51456;oat=Offer;rl=INVITE sip:[email protected]:5060;rinstance=ca13e512711def0c SIP/2.0
13:47:21.015|.\Endpoint.cpp(75)|Trace5|Endpoint|Endpoint::findSource:No Remote-Party-ID header found
13:47:21.031|.\Endpoint.cpp(95)|Trace5|Endpoint|Endpoint::findSource:Lines Is here
13:47:21.031|.\Endpoint.cpp(110)|Trace5|Endpoint|Endpoint::findSource:Only one lines is here
13:47:21.031|.\Endpoint.cpp(116)|Trace5|Endpoint|Endpoint::findSource:Settings for caller is found: CfgExtLine:10002
13:47:21.031|.\Call.cpp(122)|Trace5|CallControl|CallLegImpl::eek:nIncoming:Endpoint is built: Ln:10002@Callcentric
13:47:21.562|.\Call.cpp(661)|Trace5|CallControl|CallLegImpl::initMSEndpoint:Created external MS endpoint for Ln:10002@Callcentric: addr=76.212.49.172:9002
13:47:21.562|ServerInviteSession.cxx(91)|Trace5|Resip|>>:UAS_Offer: provisional(100)
13:47:21.562|InviteSession.cxx(2046)|Trace5|Resip|>>:Transition UAS_Offer -> UAS_EarlyOffer
13:47:21.562|.\ISHandler.cpp(140)|Trace5|CallControl|ISHandler::eek:nReadyToSend:InviteSession(51456) sends SIP/2.0 100 Trying
13:47:21.562|.\CallConf.cpp(95)|Log2|CallControl|CallConf::eek:nIncoming:Call(C:1B): Incoming call from Ln:10002@Callcentric to sip:[email protected]
13:47:21.562|.\CallStrategies.cpp(415)|Trace5|CallManager|StratInOut::initialize:Initialize InOut call strategy
13:47:21.609|.\ExtLine.cpp(215)|Trace5|Endpoints|ExtLine::getTargetOverride:Look for target override
13:47:21.625|.\CallTarget.cpp(1257)|Trace5|CallManager|CallTarget::create:Create IVR Target
13:47:21.625|.\CallConf.cpp(107)|Trace5|CallControl|CallConf::eek:nIncoming:MediaServer could be used for this call
13:47:21.625|.\ISHandler.cpp(157)|Trace5|CallControl|ISHandler::eek:nOffer:Offered: is=51456; rl=INVITE sip:[email protected]:5060;rinstance=ca13e512711def0c SIP/2.0
13:47:21.625|.\CallStrategies.cpp(605)|Trace5|CallManager|StratInOut::eek:nOffer:InOut: got offer from 10002@L:1@C:1b
13:47:21.625|.\CallEvents.cpp(78)|Trace5||FireStatusEvent:Fire event: Calling; DN 10002
13:47:21.625|.\Call.cpp(1148)|Trace5|CallControl|CallLegImpl::provideAnswer:provide answer (MS) to 10002@L:1@C:1b
13:47:21.625|ServerInviteSession.cxx(251)|Trace5|Resip|>>:UAS_EarlyOffer: provideAnswer
13:47:21.625|InviteSession.cxx(2046)|Trace5|Resip|>>:Transition UAS_EarlyOffer -> UAS_EarlyProvidedAnswer
13:47:21.625|ServerInviteSession.cxx(443)|Trace5|Resip|>>:UAS_EarlyProvidedAnswer: accept(200)
13:47:21.625|InviteSession.cxx(2046)|Trace5|Resip|>>:Transition UAS_EarlyProvidedAnswer -> UAS_Accepted
13:47:21.625|.\ISHandler.cpp(140)|Trace5|CallControl|ISHandler::eek:nReadyToSend:InviteSession(51456) sends SIP/2.0 200 OK
13:47:21.625|.\ISHandler.cpp(74)|Trace5|CallControl|ISHandler::eek:nConnected:ConnectedUAS: is=51456;rl=SIP/2.0 200 OK
13:47:21.625|.\Call.cpp(247)|Trace5|CallControl|CallLegImpl::eek:nConnected:Connected: 10002@L:1@C:1b
13:47:21.625|.\CallStrategies.cpp(646)|Trace5|CallManager|StratInOut::eek:nConnected:InOut: got Connected from 10002@L:1@C:1b
13:47:21.625|.\CallEvents.cpp(78)|Trace5||FireStatusEvent:Fire event: Connected; DN 10002
13:47:21.656|.\Call.cpp(260)|Log2|CallControl|CallLegImpl::eek:nConnected:Call(C:1B): Created audio channel for Ln:10002@Callcentric (204.11.192.22:49506) with Media Server (76.212.49.172:9002)
13:47:21.656|.\Endpoint.cpp(75)|Trace5|Endpoint|Endpoint::findSource:No Remote-Party-ID header found
13:47:21.671|.\Endpoint.cpp(95)|Trace5|Endpoint|Endpoint::findSource:Lines Is here
13:47:21.671|.\Endpoint.cpp(110)|Trace5|Endpoint|Endpoint::findSource:Only one lines is here
13:47:21.671|.\Endpoint.cpp(116)|Trace5|Endpoint|Endpoint::findSource:Settings for caller is found: CfgExtLine:10005
13:47:21.671|DialogUsageManager.cxx(1190)|Trace5|Resip|>>:Got: SipReq: OPTIONS 0005*[email protected]:5060 tid=6b18d7d9 cseq=OPTIONS [email protected] / 102 from(wire)
13:47:21.781|DialogUsageManager.cxx(1190)|Trace5|Resip|>>:Got: SipReq: ACK [email protected]:5060 tid=-6bb829b6980ff50cd982a42d543fc213 cseq=ACK [email protected]:5060 / 1 from(wire)
13:47:21.781|DialogUsageManager.cxx(1516)|Trace5|Resip|>>:Handling in-dialog request: SipReq: ACK [email protected]:5060 tid=-6bb829b6980ff50cd982a42d543fc213 cseq=ACK [email protected]:5060 / 1 from(wire)
13:47:21.781|ServerInviteSession.cxx(684)|Trace5|Resip|>>:dispatchAccepted: SipReq: ACK [email protected]:5060 tid=-6bb829b6980ff50cd982a42d543fc213 cseq=ACK [email protected]:5060 / 1 from(wire)
13:47:21.781|InviteSession.cxx(2046)|Trace5|Resip|>>:Transition UAS_Accepted -> InviteSession::Connected
13:47:21.781|.\ISHandler.cpp(82)|Trace5|CallControl|ISHandler::eek:nConnectedConfirmed:ConnCfmd: is=51456;rl=ACK sip:[email protected]:5060 SIP/2.0
13:47:21.781|.\Call.cpp(281)|Trace5|CallControl|CallLegImpl::eek:nConnCfmd:ConnCfmd: 10002@L:1@C:1b
13:47:21.906|DialogUsageManager.cxx(1190)|Trace5|Resip|>>:Got: SipReq: BYE [email protected]:5060 tid=-fba946f41c85c18411c29a99c7a9ea96 cseq=BYE [email protected]:5060 / 2 from(wire)
13:47:21.906|DialogUsageManager.cxx(1516)|Trace5|Resip|>>:Handling in-dialog request: SipReq: BYE [email protected]:5060 tid=-fba946f41c85c18411c29a99c7a9ea96 cseq=BYE [email protected]:5060 / 2 from(wire)
13:47:21.906|InviteSession.cxx(1592)|Trace5|Resip|>>:Received SipReq: BYE [email protected]:5060 tid=-fba946f41c85c18411c29a99c7a9ea96 cseq=BYE [email protected]:5060 / 2 from(wire)
13:47:21.906|.\ISHandler.cpp(140)|Trace5|CallControl|ISHandler::eek:nReadyToSend:InviteSession(51456) sends SIP/2.0 200 OK
13:47:21.906|InviteSession.cxx(2046)|Trace5|Resip|>>:Transition InviteSession::Connected -> InviteSession::Terminated
13:47:21.906|.\ISHandler.cpp(100)|Trace5|CallControl|ISHandler::eek:nTerminated:Terminated: is=51456;reason=PeerEnded;rl=BYE sip:[email protected]:5060 SIP/2.0
13:47:21.906|.\CallStrategies.cpp(690)|Trace5|CallManager|StratInOut::eek:nHangUp:InOut: got Hang-Up from 10002@L:1@C:1b
13:47:21.906|.\CallStrategies.cpp(721)|Log2|CallManager|StratInOut::eek:nHangUp:Call(C:1B): Call from Ln:10002@Callcentric to 450 has been terminated
13:47:21.906|.\CallEvents.cpp(78)|Trace5||FireStatusEvent:Fire event: OnHook; DN 10002
13:47:21.906|.\CallConf.cpp(413)|Trace5|CallControl|CallConf::~CallConf:Destroying call C:1B
13:47:21.921|.\CallStrategies.cpp(850)|Trace5|CallManager|StratInOut::~StratInOut:InOut: strategy is terminated
13:47:22.437|.\Call.cpp(1344)|Trace5|CallControl|CallLegImpl::~CallLegImpl:Leg 10002@L:1@C:1b is destroyed
13:47:22.437|.\MSInterface.cpp(540)|Trace5||??:MSLogReports
13:47:22.437|.\SLServer.cpp(264)|Error1|MediaServer|MediaServerReporting::RTPReceiver:from 'bi-server:0/MediaServer':No RTP packets were received on 00000022@:remoteAddr=204.11.192.22:49506,extAddr=76.212.49.172:9002,localAddr=0.0.0.0:9002
We dont support G729. You must have your provider use G711 or GSM. If your provider does not support it you will have to use another provider.
I'm just starting with all this stuff, so please explain.
You're saying that you dont support G729, however when I route this call directly to an extention, it's working fine.
It's just when it's going to the attendend that the call gets dropped.
Probably your phone supports G729. So therefore it would seem that the VOIP provider and phone can talk to each other because they both support G729. However when it goes to our Auto attendant, it does not support G729 and can not communicate with the provider.
Just FYI, G729 is not supported for licensing reasons. Its licensing is prohibitive. GSM is more or less the same but is free. Use G711, or if you must use less bandwidth choose a provider that supports GSM.
This is what callcentric told me :
We placed test calls to all 3 of your numbers and the only difference we found is with the codec's that are being offered; and what your equipment responds with - although there is no actual "problem" in the signaling.
On the 2 ported numbers; for example 18324822559 we offer:
G729 & PCMU
Your equipment answers these calls with only PCMU offered; and then it (your equipment) drops the call.
On the original number we assigned to you we offer:
G729 , PCMU & PCMA
and your equipment answers these calls with: PCMU and PCMA.
So the call gets dropped with PCMU (which is 711 right?)[/i]
At present Call centric is not a supported provider, i recommend you use a supported provider instead.
Getting Started - Admin
robynL
Get 3CX - Absolutely Free!
3CX
