Galaxy Note > 3CX client > Answer button
Discussion in 'Android' started by business54, Mar 29, 2017.
  1. business54
    Apr 20, 2016
    68
    12
    I have a user complaining that sometimes a call will come in to his 3CX client but the "answer" and "decline" buttons are not showing up. This doesn't happen every-time of course. So far we resent the config file from 3CX to his device and installed. That did not resolve the issue and now we have deleted the app and reinstalled. He is currently testing after this step. His device is a Galaxy Note.
  2. complex1
    complex1 Active Member
    Jan 25, 2010
    813
    46
    Are you running the latest version 3CX Client for Android 15.0.71
    This is fixed in this edition: “Bottom operations bar was disappearing
