Galaxy S i9000M Works Great Except 1 issue
Discussion in 'Android' started by story, Oct 22, 2010.
  1. story
    Oct 22, 2010
    I am using Froyo on Galaxy S i9000M.
    Everything works great. 3G + HSPA voice quality is very good. It's better than Fring for stablilty.
    However, when I press the Volume button while the program is in background, it would change the "In-Call Volume" instead of System Volume.
    This screws things up a bit
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,406
    81
    Thanks for the report. It seems you're right.
    The 3CXPhone shouldn't have any control over the system volume controls when in the background.
    Although we already made a fix for this, it seems the issue has reappeared.
    In any case thanks, i'll take a look at it.
  3. Sarah Hastings
    Nov 24, 2010
    15
    Same case here but i very rarely place 3CXphone in the background....i will try other spftwares and maybe there will be one without a bug in it
