<?xml version="1.0"?>
<doc xmlns:tcx="http://www.3cx.com">
<header>
<type>gateway-template</type>
<version>42985</version>
<time>2015-04-18 18:30:00</time>
<name>Gamma</name>
<url>http://www.gamma.co.uk</url>
<image>gamma.png</image>
<description>UK</description>
<priority>2</priority>
</header>
<data>
<device>
<type>provider</type>
<manufacturer>Gamma</manufacturer>
<model>Provider</model>
<!-- Friendly Name -->
<field name="Name">Gamma</field>
<!-- Hostnames and Port Numbers -->
<field name="RegistrarHost">88.215.63.3</field> <!-- Registrar & Proxy IP / FQDN -->
<field name="RegistrarPort">5060</field> <!-- Registrar & Proxy Port Number -->
<field name="ProxyHost"></field> <!-- Proxy IP / FQDN -->
<field name="ProxyPort"></field> <!-- Proxy Port Number -->
<field name="StunServerHost"></field> <!-- StunServer IP / FQDN -->
<field name="StunServerPort"></field> <!-- StunServer Port Number -->
<!-- Registration Settings -->
<field name="LineAuthenticationPassword" status="readonly"></field>
<field name="RegistrationExpiry">120</field> <!-- Registration Expiry -->
<field name="RequireAuthFor">1</field> <!-- No=1; In=2; Out=3; Both=4 -->
<field name="IpInContactReg">1</field> <!-- Ext=1; Int=2; Both=3; Specified=4 -->
<field name="IpInContactRegList"></field> <!-- List of PBX IPs -->
<field name="3wayauthenticationid" status="readonly"></field> <!-- Entry to enable 3 way authentication-->
<!-- Provider Capabilities -->
<field name="IsSupportReinvite">0</field> <!-- Yes=1; No=0 -->
<field name="IsSupportReplaces">0</field> <!-- Yes=1; No=0 -->
<field name="DisableVideo">1</field> <!-- Yes=1; No=0 -->
<field name="PublicIPVia"></field>
<!-- Location of Destination Number -->
<field name="DestNumberIn_TO">1</field> <!-- Yes=1; No=0 -->
<field name="DestNumberIn_REQLINEURI">1</field> <!-- Yes=1; No=0 -->
<field name="DestNumberIn_RPID_CALLED">0</field> <!-- Yes=1; No=0 -->
<!-- Other Options -->
<field name="IsBindToMS">1</field> <!-- Bound=1; NotBound=0 -->
<field name="UseIPInContact">0</field> <!-- UseIP=1; DoNotUseIP=0 -->
<field name="CallerIDIn">1</field> <!-- Fm=1; To=2; ReqURI=3; Con=4; RemPtyClg=6 -->
<field name="CalledNumberIn">2</field> <!-- Fm=1; To=2; ReqURI=3; Con=4; RemPtyCld=5 -->
<codecs>
<codec rfcname="pcmu"/>
<codec rfcname="pcma"/>
<codec rfcname="gsm"/>
</codecs>
<!--Source Identification - Use Default PBX Internal Source Identification-->
<!--<field name="MatchStrategy">1</field>-->
<!--<field name="Source" parameter="" custom=""></field>-->
<!-- Gateway / Provider Inbound Parameters -->
<!--<field name="ParameterIn" custom="" parameter="RequestLineURIUser"></field>-->
<field name="ParameterIn" custom="" parameter="RequestLineURIHost">$DevHostPort</field>
<!--<field name="ParameterIn" custom="" parameter="ContactUser"></field>-->
<field name="ParameterIn" custom="" parameter="ContactHost">$DevHostPort</field>
<field name="ParameterIn" custom="" parameter="ToDisplayName">$CalledName</field>
<field name="ParameterIn" custom="" parameter="ToUserPart">$CalledNum</field>
<!--<field name="ParameterIn" custom="" parameter="ToHostPart"></field>-->
<field name="ParameterIn" custom="" parameter="FromDisplayName">$CallerName</field>
<field name="ParameterIn" custom="" parameter="FromUserPart">$CallerNum</field>
<!--<field name="ParameterIn" custom="" parameter="FromHostPart"></field>-->
<!--<field name="ParameterIn" custom="" parameter="UserAgentTextString"></field>-->
<!--<field name="ParameterIn" custom="" parameter="RemotePartyIDCalledPartyDisplayName"></field>-->
<!--<field name="ParameterIn" custom="" parameter="RemotePartyIDCalledPartyUserPart"></field>-->
<!--<field name="ParameterIn" custom="" parameter="RemotePartyIDCalledPartyHostPart"></field>-->
<!--<field name="ParameterIn" custom="" parameter="RemotePartyIDCallingPartyDisplayName"></field>-->
<!--<field name="ParameterIn" custom="" parameter="RemotePartyIDCallingPartyUserPart"></field>-->
<!--<field name="ParameterIn" custom="" parameter="RemotePartyIDCallingPartyHostPart"></field>-->
<!--<field name="ParameterIn" custom="" parameter="ProxyAuthID"></field>-->
<!--<field name="ParameterIn" custom="" parameter="ProxyAuthRealm"></field>-->
<!-- Gateway / Provider Outbound Parameters -->
<field name="ParameterOut" custom="" parameter="RequestLineURIUser">$CalledNum</field>
<field name="ParameterOut" custom="" parameter="RequestLineURIHost">$GWHostPort</field>
<field name="ParameterOut" custom="" parameter="ContactUser">$AuthID</field>
<field name="ParameterOut" custom="" parameter="ContactHost">$ContactURI</field>
<field name="ParameterOut" custom="" parameter="ToDisplayName">$CalledName</field>
<field name="ParameterOut" custom="" parameter="ToUserPart">$CalledNum</field>
<field name="ParameterOut" custom="" parameter="ToHostPart">$GWHostPort</field>
<field name="ParameterOut" custom="" parameter="FromDisplayName">$OutboundCallerId</field>
<field name="ParameterOut" custom="" parameter="FromUserPart">$AuthID</field>
<field name="ParameterOut" custom="" parameter="FromHostPart">$GWHostPort</field>
<!--<field name="ParameterOut" custom="" parameter="UserAgentTextString"></field>-->
<!--<field name="ParameterOut" custom="" parameter="RemotePartyIDCalledPartyDisplayName"></field>-->
<!--<field name="ParameterOut" custom="" parameter="RemotePartyIDCalledPartyUserPart"></field>-->
<!--<field name="ParameterOut" custom="" parameter="RemotePartyIDCalledPartyHostPart"></field>-->
<field name="ParameterOut" custom="" parameter="RemotePartyIDCallingPartyDisplayName">$OutboundCallerId</field>
<field name="ParameterOut" custom="" parameter="RemotePartyIDCallingPartyUserPart">$OutboundCallerId</field>
<field name="ParameterOut" custom="" parameter="RemotePartyIDCallingPartyHostPart">$GWHostPort</field>
<!--<field name="ParameterOut" custom="" parameter="ProxyAuthID"></field>-->
<!--<field name="ParameterOut" custom="" parameter="ProxyAuthRealm"></field>-->
</device>
</data>
</doc>
