- Joined
- Jan 6, 2017
- Messages
- 25
- Reaction score
- 8
I'm using CFD to build our main number IVR. There's a lot more functionality than just using virtual extensions and the standard IVR. I had originally tried using a couple of IVR and virtual extensions to achieve my requirements. But with the minimum 1 second forwarding delay on extensions, there were gaps which were clearly noticeable.
At the top of the CF, I have a 'Welcome' announcement, followed by a 2nd announcement (this WAV file will be dynamic, using another CF to allow the boss to insert important messages on snow days, etc). Normally the 2nd announcement is blank (and will be a 0 second WAV file). Following the announcements is a menu with various options.
I've checked the test WAV files in Audacity and trimmed the start and end of the audio to ensure there's no silent gaps. However, I've noticed that between each Prompt Playback, there's a gap of about a second. I can't explain it.
Is the CFD inserting a gap? If so, why and could this be controllable in a future version? I would prefer there to be no delay between each step / prompt. Ideally, if a delay is required, it would be a variable (e.g. 1 second).
Or, am I doing something wrong?
Thanks.
Thanks.
