Gateway and SBC.
Discussion in '3CX Phone System - General' started by ids, Jun 11, 2015.
  1. ids
    ids
    Mar 30, 2009
    Can use a pstn gateway in a sbc remote office.
    I like to integrate te remote pstn lines to the system.
    3cx system vesion 12.
    Raspberry pi SBC.
    11,095
    327
    This has come up before, and the general consensus was no, it won't work. Using a gateway, and a number of sets in a remote location on will require the use of VPN.
