Gateway for skype hardware
Discussion in '3CX Phone System - General' started by twincore, May 10, 2010.
  1. twincore
    Nov 25, 2009
    Hi all
    I just installed my first gateway for skype on a windows server 2003. Incoming and outgoing calls work ok but sound is not that great. I have created four accounts to handle incoming and outgoing calls from the gateway. On the IBM server who had no sound cards as a quick solution I installed a plantronics usb headset to act as the sound card. Should I install an internal sound card (maybe a soundblaster) would it make a difference or is it something in skype config? I'm using cisco SPA504G phones.
    Stelios
