Gateway for Skype service starts then immediately stops
Discussion in '3CX Phone System - General' started by gzimmerman, Jun 18, 2010.
  1. gzimmerman
    Jun 17, 2010
    I have installed and reinstalled both skype and 3CX Gateway for Skype several times always same result. When I am installing the 3CX Gateway it seems to install OK but does not open instead I get the error "Gateway configuration program is already in use by another computer user, please try again later!" There are no other users logged into the machine, I am using Windows XP Pro SP3 on a Compaq Presario SR1300nx.
