Gateway GSM for 3CX
Discussion in '3CX Phone System - General' started by davidepet, Nov 21, 2008.
  1. davidepet
    Sep 12, 2008
    5
    Hello everyone,
    I wanted to ask what GSM gateways are supported by 3CX
    and which of these are recommended.
    Thank you in advance for your reply.
    David
  2. Pentangle
    Pentangle Member
    Dec 6, 2007
    261
    Actually here's the list from the Wiki of the community-tested gateways.
    http://wiki.3cx.com/Home/community-supported
    I've got a Portech 372 and can recommend it. It works flawlessly.
    Mike.
  3. Pentangle
    Pentangle Member
    Dec 6, 2007
    261
    That's because between me posting it and you viewing it, some bugger's been playing with the wiki.
    It now appears to be a subsection at: http://wiki.3cx.com/Home/supported-gateways
