Gateway issue?
Discussion in '3CX Phone System - General' started by huzer1, Nov 29, 2007.
  1. huzer1
    Oct 30, 2007
    33
    I have an Audiocodes MP-114 gateway. My issue is when you call it, first it takes 2 rings to answer. When it does answer the phone it gives you a dial tone, after the dial tone sits for about 5 seconds it will go quiet for about another 2 THEN it will forward the phone call to the proper extension. Outbound calls don't have an issue at all.
    The only other issue I'm aware of currently is when you recieve a call, put it on hold, then try to transfer it, another extension, or voicemail it will hang up on the call.
    Thanks for the help.
  2. Mori
    Mori New Member
    Mar 23, 2007
    223
    So this is exclusive internal problem?
    We had a similar problem, found out it was caused by local SIP domain.
    I removed this and it worked.
    We dont use MP-114 so regarding that i dont know.
    Have you any other extensions using other gateways or softphones with the same problem?
  3. huzer1
    Oct 30, 2007
    33
    Sorry I was a little misleading, this is from calling external. internal calls work without an issue
  4. kustura
    Nov 2, 2007
    53
    Did you find the fix
    Hello Huzer1,
    I have exact same problem with MP-118. Did you find the fix for the problem?
    Tom
  5. alicic
    alicic New Member
    Oct 3, 2007
    119
    Hallo,
    I am having the same problem. I am working on it with AudioCodes personels.
    Hopefully we will find the solution;-)
    regards,
  6. kustura
    Nov 2, 2007
    53
    To fix this problem you have to change the following setting:
    Protocol management à endpoint settings à automatic dialing .
    Put the destination phone numbers corresponding to the channel numbers, these are the phone numbers on the PBX that will be dialed automatically by the MP. ( I think for your case these are the same as your endpoint numbers) Put the autodial status to enable.
    On 3CX' website, configuration instructions incorrectly specify to change this setting to "Hotline".
  7. huzer1
    Oct 30, 2007
    33
    Ok thank you, that fixed the problem :p
