Gateway WellGate 3804A - Does not registered
Discussion in '3CX Phone System - General' started by jmareco, May 4, 2007.
  1. jmareco
    Dec 3, 2006
    6
    WellGate 3804A. I
  2. Anonymous
    Anonymous Guest
    Not sure what you are asking, but I have a go at it.
    The gateway must be configured in the software. Typically the gateway will have an IP address, this is what you use to configure it in 3cx.
    Also it might require a authentication this is configured in the Line configuration in 3CX.
    Hope this helps.
