Gateway with built in PRI
Discussion in '3CX Phone System - General' started by bblokey, May 5, 2008.
  1. bblokey
    Apr 15, 2008
    57
    Does anyone have any recommendations on a gateway with a built in pri port? Or pci cards that work with 3cx?
  2. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    Patton makes some very nice gatways with PRI. There are currently no PCI cards that will work with Windows (that I know of) or with 3CX.
