Gateway with GSM
Discussion in '3CX Phone System - General' started by pstmg, Dec 5, 2013.
  1. pstmg
    Dec 9, 2012
    49
    Hello all,
    does anyone know how to set up a gateway between 3CX Server and GoIP1. It's required to receive and make calls
    Manufacturer product link: http://www.dbltek.com/products/goip-1.html
    Paul
  2. DJHiP
    Dec 2, 2009
    29
    Does it not work with a Generic VoIP/PSTN Gateway configuration?
  3. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    Check Ukrainian forum -- it was explained somewhere there how to configure it: http://3cx.com.ua, but you need to (google) translate from Russian. However, GoIP is not recommended brand to use, nevertheless it seems been working.
    See: http://3cx.com.ua/node/789 and http://3cx.com.ua/node/794 (and may be other posts).
  4. pstmg
    Dec 9, 2012
    49
    Thank you so much eagle2. Your info was really really usefull. I got it up and running for incoming and outgoing calls. The forums ware very helpfull altought the device explained was a GoIP4 :)
    Have a nice weekend
    Paulo Gonçalves
