gateways + codecs
Discussion in '3CX Phone System - General' started by iperez_genius, Aug 5, 2008.
  1. iperez_genius
    Jul 1, 2008
    56
    In general is it possible to add codecs to the list that a gateway provides?
    I have a gradnstream 4xxx and it only has
    PCMU
    PCMA
    G.273.1
    G.729A/B
    GSM
    which maybe enough...not the point, can i add different codecs as i wish...if so how?
  2. alexmallia
    alexmallia New Member
    3CX Support
    Aug 4, 2008
    130
    the list of codex that may be selected in the grandstream configuration is the list of codex that the device supports. It means that other codex are not supported by this device.
    Any additional codex can only be included by a firmware update from the grand stream manufacturer.
    regards
  3. iperez_genius
    Jul 1, 2008
    56
    right and i assume this concept applies to all devices...in general
    no need for a reply...thanks for the help
    thats probably obvious to most people :)
    Ilan
  4. iperez_genius
    Jul 1, 2008
    56
    so then my next questioin is...
    does anyone have a gateway that support really high end codecs, that have a greater sampling rate than 8000 Hz
    does anyone know where i can find this information?
    Ilan
  5. moon1234
    Jan 25, 2008
    24
    The analog PSTN does not need to support rates higher than 8K as the PSTN does not resolve anything that high. If you were to use a PRI or BRI gateway then you could use PCMU in the US or PCMA in the UK (You will need a PRI, BRI or channelized digital connection like a T-1, ISDN or E1. PCM should be the highest end PSTN connection you will ever need. The only way to get better voice quality is a direct IP connection between all endpoints.
