GCM
Discussion in '3CX Phone System - General' started by donbru01, Dec 1, 2014.
  1. donbru01
    donbru01 New Member
    Nov 30, 2011
    134
    Hi at all ,
    GCM APIs service for 3CX Push notification is chargeable or free with limitations ( side Google ) ?
    Hi don't know if Google need royaltis for use this service .
    Thanx
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    This is more a question for Google, it is free and as far as I know there are no limits, found this page on the subject : http://stackoverflow.com/questions/15017486/android-push-notification-gcm-is-there-any-daily-limit
