General Enuiry regarding VOIP
Discussion in '3CX Phone System - General' started by KevinG, Oct 6, 2008.
  1. KevinG
    Oct 6, 2008
    I'm new to your website. I'm currently looking for some reliable, cheap, and good VOIP providers.
    Please answer all my questions:
    1) Are you a VOIP provider?
    2) Which countries do you cover?
    3) What is the cost, if I take your service?
    4) I'm making a website where many people can use that website to call anyone on their mobile or land line. Do you provide that service? (If I take your service will I be able to install it on my servers and provide that service to my customers?
    5) Do I need anything else after I get your service?
    Please answer all the questions above and please get back to me as soon as possible.
    I will be waiting for an detailed reply.
    Thank You
    Kevin Gupta
  2. galal202
    galal202 New Member
    Jun 23, 2008
    235
    Hello and welcome,
    No, 3CX is IP PBX Phone System for windows
    All
    IT depends
    http://www.3cx.com/ordering/pricing.html
  3. galal202
    galal202 New Member
    Jun 23, 2008
    235
    Your ansower before edit was nothing
    5=wrong ansower=you did not understand his question
  4. KevinG
    Oct 6, 2008
    Ok, so it means that I must buy 3cx and then use one 3cx VOIP partners regarding that? Is that right?
  5. galal202
    galal202 New Member
    Jun 23, 2008
    235
    3CX will manage your calls with a lot of features
    you can use more than voip lines and/or pstn lines from anywhere
    to dial and recieve calls from your extensions at local lan or remote using internet from all the world
  6. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    You can use free edition...(you are not obligated to buy anything but 3CX will not provide warranty as well as will not provide any support for you, sorry)
    You can use any VoIP providers or any equipment, it is completelly up to you... (requirements are described in documentation)
    You can implement your own VoIP provider for your friends and pay only to your Internet service provider (traffic) even if you are using free edition...
    In my opinion, your questions is slightly strange, at least on this forum...
    Reason: Here are a thousand answers for yourquestions :)
    Regards
