Generic SIP trunk configuration problem password lenght
Discussion in 'Windows' started by mic.max, Nov 17, 2016.
  1. mic.max
    Nov 24, 2010
    56
    I configure a SIP trunk for voip service but unfortunately 3cx allow password leght 50 char max, i've a password of 64 char lenght and i can not change password. There is a work around to solve this problem?
    thanks
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,341
    535
    Unfortunately this is hard coded into the PBX so i do not see a way around this.
    What do you mean by you cannot change password? Is the password defined by the provider?
  3. mic.max
    Nov 24, 2010
    56
    Thank's for reply!
    Yes password is defined from provider and cannot be changed by user !
    there are probability then 3CX increase a password field lenght ?
  4. YiannisH_3CX
    May 10, 2016
    7,341
    535
    You can raise this as a feature request in our ideas section and if it gets enough votes it might get implemented
    http://www.3cx.com/forums/3cx-ideas-f57.html
    For now i would recommend contacting your provider and ask them if they can provide you with a smaller password. I believe 50 characters long password is secure enough.
  5. mic.max
    Nov 24, 2010
    56
    Thank you YiannisH_3CX, unfortunately SIP provider provide password with lenght 64 char, is not possible to have password too short!
    I open request in http://www.3cx.com/forums/3cx-ideas-f57.html !
