Generic Sip trunk invite issue
Discussion in '3CX Phone System - General' started by choimarc, Feb 11, 2017.
  1. choimarc
    Feb 19, 2014
    77
    8
    I have a big problem right now. It seems since I have upgraded to V15 SP4, there's something wrong with the invite with oubound calls. The from field is not formed correctly. It's missing the user part and the host part is the same ip as the destination ip address. I have tried a lot of things in the outbound parameter tab of the trunk but nothing changes ( i'm watching the sip invites with wireshark directly on the 3cx server). This is a problem since the system connected at the other end of the trunk is not behaving as expected. Does anyone have a clue as to what is going on ?
    Thanks.
    11,083
    325
    Have you tried deleting the trunk and re-building it?
  3. choimarc
    Feb 19, 2014
    77
    8
    Absolutely. Deleted and recreated them multiple times. I have found on the forum that by modifying the trunk and saving it, it sometimes solves the problem. It didn't in my case. I have planned downgrading to v15 vSP3. Any tips concerning this ?
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,341
    535
    It sounds like you are connecting 3CX pbx with another PBX. Do you have multiple trunk lines going between them? Are the trunks authentications IP based or registration based?
  5. choimarc
    Feb 19, 2014
    77
    8
    It's ip based. I use the option "Configure how 3CX should identify calls coming from this trunk" in inbound parameters to have the incoming calls pass thru the right trunks. Since SP4 (windows), I have a lot of problems. As for the outgoing parameters, whatever mapping I use to configure the invite to the other system, the data doesn't change at all. So I cannot fine-tune the invite for the other system so that everything works well together. Again, since SP4.
  6. YiannisH_3CX
    May 10, 2016
    7,341
    535
    I have sent you a p.m
