Generic SIP Trunk provisioning
Discussion in '3CX Phone System - General' started by infotrust, Jul 8, 2010.
  1. infotrust
    Apr 1, 2010
    Hi all,
    I am trying to setup my telco (with the credentials they have provided as VOIP) via a SIP Trunk as they have not given me a Authentication ID or password. I have tried the "Generic SIP Trunk" option only to be told that I need a Auth. ID and P/word - thus it seems that it starts the "Generic VoIP Provider" wizard.
    Any ideas how I can over come this problem? I was thinking to set a ID and P/word but then to go back and delete it after the wizrad has completed... Would this work?
    Thanks!
  2. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    Usually just put in dummy info and it will work.
