Generic sip trunk
Discussion in '3CX Phone System - General' started by Ravilla, Mar 23, 2018.
  1. Ravilla
    Oct 4, 2017
    36
    Hi all member,
    i am trying to configure 3CX sip ip based using sip trunk. the color of the trunk show green but seem not send any register package and doesn't have register status also.
    note: host is sip ip that my provider gave.
    thanks for advise.
      File size:
      41.3 KB
      11
  2. eddv123
    eddv123 Active Member
    Aug 15, 2017
    653
    104
    Hi Ravilla,
    Who is your provider ? Since you are setting them up as Generic I will assume they are "unsupported": https://www.3cx.com/partners/sip-trunks/
    Also unless 100% certain also confirm if they are IP Based or Registration based. An IP Based provider will not send a REGISTER and will also show green in the 3CX interface regardless of whether they are connected and working or not.
    You can tell this easily from the providers portal or email they send you when you first acquired the service.
    craigreilly and YiannisH_3CX like this.
  3. leejor
    10,071
    201
    In the 3CX trunk options, you can choose if you actually want the trunk to attempt to register. Check that it is selected. If not, it will just show green. the fact that there are no registration failures, in the attachment, suggested it has not tried.
  4. Ravilla
    Oct 4, 2017
    36
    i am not sure about the problem. now i can make outgoing and incoming call but in the sip trunk still not show register sent, register ok and last failed register.
  5. eddv123
    Aug 15, 2017
    653
    104
    Hi Ravilla,
    Can you confirm:
    * Who the VoIP Provider is.
    * Whether they are IP authenticated or Registration based.
    * The status of the trunk green/red.
  6. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,794
    132
    You say its IP Based. Thus no registrations. This is what my IP Based trunk looks like.
