- generic sip url
Discussion in 'Windows' started by jkomorowski, May 27, 2012.
  1. jkomorowski
    May 27, 2012
    My contact has the sip address of the form
    sip:name@domain
    e.g. sip:john.smith@domain.com
    How I can call him with 3CX Phone ?
    Regards,
    10,758
    286
    If you are trying to place a direct SIP call to them you will have to build a new trunk group that goes to "domain.com". then because you can t dial john.smith from a regular phone, you will have to create an outbound rule that will strip some digits that you do dial nag add on john.smith before sending it out on the new trunk group that you created.
    Of course this become cumbersome if there are a lot of contacts at a lot of domains, but for one or a few, it should work.
  3. jkomorowski
    May 27, 2012
    Thank you for the answer.
    Could you be so kind and point me to a reading where I can learn
    - how to build a new trunk group that goes to "domain.com"
    - how to create the outbound rule you mention in your answer.
    Regards
  4. leejor
    10,758
    286
    Sorry, I should have paid closer attention to the forum that I was in... :(
    You cannot do direct SIP calls with the 3CX phone, unless it has been added in the most recent version and I hadn't heard about it.
    You'd have to run it as an extension off the 3CX PBX. The PBX would allow a direct SIP call adding the name as required.
  5. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    3CX Phone does not compete to the SIP clients which allow to make a call to any URL at any time.
