Gerdes Primux 2S0
Discussion in '3CX Phone System - General' started by sebastian.claus, Dec 18, 2008.
  1. sebastian.claus
    Dec 8, 2008
    Hello, I would like a Gerdes Primux 2SO map with the 3cx 7,0 to run to get. One of you has thereby already experience.
    Friendly greetings Sebastian Claus
  2. kevin
    kevin Member
    Nov 23, 2006
    316
    Hi there
    This card is unsupported.
    However, if you want to interface this card with 3CX, the first thing you will need to do is obtain from the manufacturer a SIP driver for the card.
    Hope this helps.
    Regards
    Kevin
