Get back to automated assistant from voicemail
Discussion in '3CX Phone System - General' started by brianfpmoab, Apr 26, 2007.
  1. brianfpmoab
    Mar 15, 2007
    17
    Im not sure if this is a feature or not. I have perused the manual and I do not see this functionality.
    I call into the system and the automated assistant answers the call and I am transfered to an extension but nobody is there so I get that extensions voice mail. I would like to be able to press 0 or something to get back from the voice mail of the extension to the attendant so I can try another extension.
    Thanks.
    Brian
  2. Anonymous
    Anonymous Guest
    I think the only way you can do that is to configure a digital assistant for each extension.
